(2) Sensors to Analog Ground
jtrue
Post by jtrue »
I plan to run an AEM Wideband, AEM Oil Pressure, and to be determine EMap Sensor with the sensor inputs wired to 3 analog of the analog pins. With only two sensor ground pins am I able to Ground 2 sensors to 1 analog GND pin since I'll have 3 total sensors( A/F, Oil Pressure, and EMap)? Thanks!
Re: (2) Sensors to Analog Ground
You should be able to. You will have to try it.
