Fan control, turn off??
EGK2082
Post by EGK2082 »
Override radiator fan control
when does my fan turn off? I configure it to turn on at 90 ° c and when it turns off? If I set 100km/h, does it not turn off until it reaches that speed? meanwhile will it stay on all the time?
Re: Fan control, turn off??
Details are in the help file: https://hondata.com/help/smanager/prote ... protection
You should also have a thermoswitch to control the fans that is built into the radiator or cylinder head.
DaX
Post by DaX »
If you set it to 90C / 110km/h:
As long as the vehicle is below 110 km/h, the fan will turn on at 90C, then off when it drops below 90C.
If the vehicle is over 110 km/h, the fan will turn off.
EGK2082
Post by EGK2082 »
Perfect, thanks
