Possible Immobiliser....
dangibernau
Post by dangibernau »
I'm having some sort of electrical issues, and im going through some things and wondered if anyone can give me a step by step guide to disabling the immobiliser so I can see if there's an issue reother fix or eliminate that possibility
dangibernau
Re: Possible Immobiliser....
For context, here's my issue.....
https://youtu.be/r9TcziYLL6o
The immobilizer cannot be disabled.
dangibernau
Well, that's screwed that idea... looks like I'll be changing the ECU and everything at this rate 😮‍💨 Unless putting ECU to standard helps.
I've currently got a map on the car that's read only, I'm assuming there's no way around that to lift it from ECU if I do have to change it
If your calibraiton is locked, then you will not be able to make any changes to it without help from the tuner that locked it.
