Honda S2000 AFR Values
Shabba07
Post by Shabba07 »
Hi There
Can someone please tell me which AF value is correct from the screenshot below, AF or AF corrected? Vehicle is a 2006 S2000.
Re: Honda S2000 AFR Values
As you get richer the lambda reading is not very accurate from the factory. Only want to know for sure is to compare with a known good lambda.
