Turbo b16 base map
noobdata
Turbo b16 base map
Post by noobdata »
Hey I’m looking for a base map just to get the car running ok. Also this is my first time for any of this so please bear with me.
I have
450 wahlbro
Stock injectors
B18c1 block and internals
B16 head that I think is stock
Gt35 eBay turbo.
P28 ecu
I’m currently waiting for a turbo exhaust flange to come in so I dont have any wideband. AlSo I removed the o2 sensor and it’s putting the car in limp mode is there a way to bypass that.
Idk what else I should list
I do plan on getting injectors
noobdata
Re: Turbo b16 base map
Post by noobdata »
Also have stock map sensor and also plan to upgrade
noobdata
Post by noobdata »
Anyone?
Boostedintegra
Post by Boostedintegra »
shoot me a private message and i can get you shorted out
noobdata
Post by noobdata »
Boostedintegra wrote: Thu May 11, 2023 1:25 pm shoot me a private message and i can get you shorted out
Sent a pm I think lol and thanks
noobdata
Post by noobdata »
Still need a base map
noobdata
Post by noobdata »
Anyone?
CalibratEd
Post by CalibratEd »
Have you tried the Stock b16 or b18 calibration files? Since you are running the stock injectors and map it should not run too bad. You can datalog the car and I can review it make sure the wideband is connected properly.
-Ed
Instagram: calibrated.tuning
noobdata
Post by noobdata »
CalibratEd wrote: Mon Jun 05, 2023 8:07 pm Have you tried the Stock b16 or b18 calibration files? Since you are running the stock injectors and map it should not run too bad. You can datalog the car and I can review it make sure the wideband is connected properly.
-Ed
Might take you up on that I haven’t put the wideband on yet since I’m still waiting on a 90 for my exhaust. Can I pm you when I’m set?
CalibratEd
Sure thing.
-Ed
