KPro Digital Output - Aim digital dash and Racepak Smartwire
CJ4A
Post by CJ4A »
Hello All,
I currently have a Kpro V4 in my Civic EP3 and I am using the RS232 signal to get information to the Aim MXL dash. I am about to rewire the car and I plan to use a Racepak Smartwire PDM. I would like to be able to connect the 230-VM-EFIHON so data can be sent from the Kpro to the Smartwire PDM.
For the AIM I have the digital output selected as ' Aim MXL'
In your instruction on this website, in order to connect to a Racepak IQ3, I have to change the digital output to Racepak IQ3. Will this need to be the same for communication to the Racepak Smartwire?
Is it possible for me to run the Aim MXL and the Smartwire and have both communicate with the Kpro ECU? If so, what would I need to do?
The AIM uses the RS232TX pin
The Racepak uses the TTL out pin.
Regards,
Jamal
Re: KPro Digital Output - Aim digital dash and Racepak Smartwire
You will need to check with Racepak to see what protocol it uses.
CJ4A
Post by CJ4A »
Hi. I have the Hondata interface cable but the setting in mutiplexer output will need to be changed from Aim MXL to Racepak. Is there anyway the Hondata can communicate with both?
You cannot output multiple signals at the same time.
CJ4A
Post by CJ4A »
Thanks a lot.
