rsx base k24 swap
rsxguy
rsx base k24 swap
Post by rsxguy »
hi im looking for help with my base map im using the stock 04_05 k24 tsx map but the car has slight misfire doesnt throw a code tho i have stock 310 injectors,aem fuel rail,70 mm skunk2 throttle body {blocked ivac},injen cai,421 headers,vibrant exhaust,belive i, running kpro v1,also my air fuel ratio is 23.27 on idle i attached my current calibration and a datalog of just driving to the store
Re: rsx base k24 swap
If your wideband is correct you are running dangerously lean.
rsxguy
Post by rsxguy »
is that what needs to be changed i bought the car like this all i did was change the transmission at first i thought it was sparks and coils but i changed those and it didnt help
rsxguy
Post by rsxguy »
everything seems to be plugged in and working at idle the car just sputters constantly
CalibratEd
Post by CalibratEd »
Like Spunkster said, the car is running very lean. I also reviewed the calibration file and it seems the o2 has been turned off so the car does not go into closed loop. I set the car to use the built in wideband and add 20% fuel to all the tables to be safe. You can dial down the fuel afterwards. Load the file and see how the car runs.
- Ed
Instagram: calibrated.tuning
rsxguy
Post by rsxguy »
thank you!! i will upload it and let u know how it works out
rsxguy
Post by rsxguy »
took it for a ride today af ratio was way better still a light sputter at idle tho but the idle is definitely way better
CalibratEd
This should be good enough to drive with no WOT. I adjusted fuel and timing where knock was present.
-Ed
