2007 HONDA CIVIC SI HYBRID RACING CAI
J_Lovell2007
Post by J_Lovell2007 »
So I installed my Hybrid racing CAI and now at start up it stutters and sounds like I have it camed lol. Did notice also when i'm around 4500-5000 RPM and I accel hard it seems like im losing power and bogs down. Did have a code P0701, I cleared it hasn't came back on? I did use my flashpro and uploaded the VEM V2 (I think that's the one). I plan on getting headers and exhaust but not for another year, it's been a slow building process. Didn't know if anyone could help me maybe adjust fuel trim? Thanks in advance
CalibratEd
Re: 2007 HONDA CIVIC SI HYBRID RACING CAI
Post by CalibratEd »
Welcome to the forum J,
The Hondata base maps are a good start and still need some work.
Post the calibration file you are running and a datalog. Try not to drive the car to hard.
I can take a look at the logs to make sure you’re running safe.
-Ed
Instagram: calibrated.tuning
J_Lovell2007
Thanks for replying, I will send some data logs over tomorrow so you can take a look at them!
CalibratEd
Sounds good.
-Ed
J_Lovell2007
datalog0003.fpdl
CalibratEd
Post the calibration file as well.
-Ed
J_Lovell2007
FG2/FA5, AEM V2 CAI
CalibratEd
J_Lovell2007 wrote: Thu May 18, 2023 8:29 pm FG2/FA5, AEM V2 CAI
Post the actual file.
-Ed
J_Lovell2007
calibration.fpcal
J_Lovell2007
Is this it? I'm kinda new to Hondata, still trying to figure it out.
CalibratEd
I looked over the log and I suggest you switch the calibration file to Speed density and then redo the log.
-Ed
J_Lovell2007
Should I have "AFM enabled" AND "use speed/destiny (MAP) fuel tables clicked?
CalibratEd
Uncheck AFM and check use map tables.
-Ed
J_Lovell2007
Ok I have the settings saved now, once im off work I will get more data logged. Do you want cold start data? Also do you want high revs or normal driving? Thanks Ed
CalibratEd
Idle log after it has reached operating temperature as well as a normal driving log. Do not wide open throttle the car.
-Ed
