2015 Civic Si Base-map Selection
Chester54647
Post by Chester54647 »
I have a 2015 Civic Si, next month I'll be getting Hondata Flashpro so I went ahead and downloaded the Flashpro manager software on my laptop so I could get familiar with it before I use it with my car. When selecting the calibration, under "Model" I chose "Civic Si (2012-2015)" and then under "Vehicle" I chose " Civic Si 2014-2015" however all of the names of the base-map calibrations and their description is 2012-2014. Just wondering if these are still the right ones to use with my car.
My civic is bone stock except for a 3.25" K&N Cold Air Intake (69-1019TS). I also wanted to know if there were any specific changes I needed to make to the calibration in regards to my Cold Air Intake before do my first test with the base-map.
Any info is greatly appreciated, Thanks
Re: 2015 Civic Si Base-map Selection
The 2015 is the same as the 2014.
You will probably need some custom tuning if the intake diameter is larger than stock. You may want to search the vault to see if anyone uploaded a similar calibration.
