Kmanager connection problem
robyabarth84
Post by robyabarth84 »
Honda Civic EP3 2005
k20A2 Engine
Ecu Number 37820-PRA-E02 2030-304417 1E09
Good morning.
I am writing for a problem.
During an upload with the Kmanager, the upload crashed and from that moment I can no longer connect to the ECU.
Kpro manager, with the ecu connected and the ignition on, says "Driver Installed/Error/ingnition off".
The green led on the ecu is on and the red one is flashing. Usb drivers and kmanager software are updated.
What can I do? I searched for an answer on the internet but I did not found it.
Thank you
Re: Kmanager connection problem
robyabarth84
Can't see any serial number on the K-Pro Board unfortunately.
The car is arrived at my workshop with the kpro installed.
The version of the software is 4.5.6.0 Build 3237 and I use windows 10.
replied via email
Diogo124
Post by Diogo124 »
Hi, I have exactly the same problem, did you find a solution? Thanks
robyabarth84
Diogo124 wrote: Fri Feb 23, 2024 3:08 am Hi, I have exactly the same problem, did you find a solution? Thanks
PM you
Diogo124
Post by Diogo124 »
robyabarth84 wrote: Fri Feb 23, 2024 3:21 am
PM you
Hello
Sorry, I can't respond by pm.
Was it counterfeit?
So you had to buy another one
You can't find a solution since it worked, it was just an upload error
