K-Pro V4 Digital Input - VSS
kiver
Post by kiver »
Hello,
I have a k-swapped kit car with K-Pro v4 that I'm trying to use the vss on the digital input pin (without success)
My first issue is, would there be any reason why i would be seeing voltage present on the VS pin of the digital input - When probed with a multi meter the pin displays 4.65v (red probe on vs pin and black probe on the ground pin) It displays this voltage with nothing connected to the pin headers as if the board is providing voltage
Secondly if this isn't the reason i cant get my current vss to work could anyone recommend a vss that works out the box with the v4 digital input.
Thanks in advance.
Re: K-Pro V4 Digital Input - VSS
What are you getting the VSS Signal from? Have you verified that it is pulsing?
Post your calibration as well as a datalog showing the issue.
