Kpro install first power up, upload failed
sykou
Post by sykou »
- what vehicle you have 1996 Honda Civic Hatch
- serial number of your K-Pro 62495
- version of software being used (from Help, About) version 4.5.6.0 Build 3237
- ECU part number 37820-PPA-A58 2829-127517 OA27
- KManager version 4.5.6
- the calibration See Attached
- K24 swap, under dash swap harness, and tucked engine harness. Both made for 02-04 RSX
- when and where you got the K-Pro July 2022 KPower Industries
- a specific description of the problem
Test upload results in "Upload failed" error.
Clear security results in "Clear Security failed" error.
Already checked for USB drivers and it is correct.
Reinstalled KManager, problem persists.
Bottom right of KManager screen shows Ignition ON.
Checked for ECU voltage at E Plug Pin 9 and it has over 12 volts consistent.
What am I missing???? Ive already emailed KPower but seeing what this group has to say while I await a response.
k20a2-rsx-stock.kal
Re: Kpro install first power up, upload failed
As this was an install kit installed by KPower it could be an installation issue. They will probably need to look at the ECU and test it.
sykou
Post by sykou »
Spunkster wrote: Tue May 30, 2023 11:28 am As this was an install kit installed by KPower it could be an installation issue. They will probably need to look at the ECU and test it.
Okay. I’ll have to send it in to them to check out then. Thanks.
Joemoma
Post by Joemoma »
I have the same problem with my Kpro and I sent it to kpower how long ago was your turn around time and what did they tell you ?
