Stock D16y8 Basemap
BlewD16y8
Stock D16y8 Basemap
Post by BlewD16y8 »
Stock D16y8, looking for a basemap. Ive got stock injectors and a 7.5 pound spring in.
CalibratEd
Re: Stock D16y8 Basemap
Post by CalibratEd »
BlewD16y8 wrote: Tue May 30, 2023 6:41 pm Stock D16y8, looking for a basemap. Ive got stock injectors and a 7.5 pound spring in.
Welcome to the forum,
Are you running a wideband? Do you plan on swapping the injectors?
What map sensor are you running?
-Ed
Instagram: calibrated.tuning
BlewD16y8
Post by BlewD16y8 »
Stock map sensor currently, I will upgrade injectors if needed. I do have a wideband, i still have to tap that into my p28. Researching that currently. Its idling great on stock ECU, but thats all ive done is idle. The dyno shop is in the town over, so i am just looking for a conservative basemap to get things going so i can get around.
CalibratEd
Have you reached out to your tuner to see if they can give you a basemap to get you to the dyno?
You will need to upgrade the injectors. They are not going to be enough for your application.
Once you get the wideband installed post the calibration file you are running and datalog of normal driving.
-Ed
