FK8 racecar HPD Motec dash OBD + flashpro
Garrett_si
Post by Garrett_si »
On a FK8 HPD race car, we have Motec dash (Mandatory) and we want to use Flashpro for logging track use, since Motec C125 by OBD don't allow to log all channels like Flashpro.
I bought a OBD2 Splitter, and when both are connected at same like, Flashpro standalone don't allow to record
Does I need a special adapter, or do special settings?
I think, the CAN or OBD bidirectionnal make an issue here
thanks
Re: FK8 racecar HPD Motec dash OBD + flashpro
The OBDII standard assigns the same address to any device on the diagnostic port (known as scan tools). The Motec would have the same address as the FlashPro. It sortof works if the datalogging rate is slow but there is an address conflict and sooner or later one of both devices will stop working.
Garrett_si
So there is no real way to have both working at same time
No there is not.
