Flashpro not available connect
ctk0209
Post by ctk0209 »
Excuse me, My Flash Pro has encountered a problem that the continuous loop download (Updating Flashpro firmware) cannot be interrupted. So i can't connect can not use .there is a solution ?
My flashpro is registered as well. Please let me know.
Flash Pro Manager:version V4.1.1.0
thank you
Re: Flashpro not available connect
Is the FlashPro plugged into the vehicle?
ctk0209
Post by ctk0209 »
Yes, plugged into the vehicle, but it's the same without the vehicle connected, and the same with the USB only
Thank you
What is the FlashPro serial number?
ctk0209
Post by ctk0209 »
Flashpro:(FP-SI-INT-25188)
After it fails to update, with everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
ctk0209
Post by ctk0209 »
ok i'll try that but i plugged everything in and the ignition in the on position ! would happen (continuous loop download (updating flashpro firmware) . Or use the USB Driver alone for connection?
Thank you
Just plug in the USB.
