whats the correct way to wire ecu fan control (a12) for cars that dont have a ecu fan control (most eu models) ?
racepak
Post by racepak »
hello everyone
i used to just run a wire from pin a12 tapped to the green wire of the fan switch. and adjust fan control from software. it worked fine but im not sure of thats the correct way to wire, it, some sources says a another relay is required,
thanks
Re: whats the correct way to wire ecu fan control (a12) for cars that dont have a ecu fan control (most eu models) ?
As long as it is using the FAN relay then it should work.
