Civic 2015 Si KN intake tune
DannGerous667
Post by DannGerous667 »
Hi, I'm new to the group. i recently got a 2015 Si. Stock execpt I installed a KN Cold Air Intake and got a FlashPRo
I uploaded the MAF tune.
here is the datalog and config. I just a short cruise at 90 kmh in 6 followed by an idle and a 3rd gear short pull.....
thank you
CalibratEd
Re: Civic 2015 Si KN intake tune
Post by CalibratEd »
These cars tend to do better running speed density tunes once you upgrade the intake.
Are you experiencing anything in particular?
I will take a look at the log once I’m at my computer.
-Ed
Instagram: calibrated.tuning
DannGerous667
Hi, thank you for fast reply
Here is some other datalogs from the same calibration.
what do you mean by speed density tune ? I don't see anything like this in the tune list. I search the vault for my calibration but the only tune listed won't onpen and flashpro manager says it seems corrupt.
KN cold air intake, exhaust stock,
CalibratEd
Speed density just means the car is using the MAP sensor rather than the MAF sensor.
-Ed
DannGerous667
ok, so which tune should I start with ? Hondata reflash ? There is another tune listed for a PRL intake...
please point me in the right direction ...
thank you
CalibratEd
The calibration file you posted is not bad fuel wise. The fuel trims are ok. There is knock. I will make adjustments when I have down time and post the file.
-Ed
