Honda Accord 2.0t 10th Gen issues after Flashpro
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
echrispot@gmail.com
Post by echrispot@gmail.com »
Hi there,
I used the Hondata flashpro approximately 10 days ago on my Accord with the stage 2 tune. Everything went great and the tune was active. Fast forward to 3 days ago and I begin to get a barrage of error messages and check engine warnings while driving but the vehicle continued to run well.
I decided to reflashed the car to stock last night to see if it would make a difference as I have service booked on Monday anyways. Last night I am driving to the gym and the car starts stuttering and I was unable to get past 60 km/hr, no boost and having issues going up hills. I stop the car for a while and it begins running fine but with the warning lights still present.
Now today I begin to play around with the Flashpro and manager again because I am becoming concerned and now when I try to use the push button start on the vehicle, I am unable to turn on the engine. So now I cant even bring the car in for service this Monday without a tow and my car is sitting in my parking spot.
Please help! I am a car modification noobie and I am worried I may be in over my head. The battery light is essentially the only light on my dash not flashing right now so I don't think I need a boost.
Thanks! If anybody is able to reach out over discord to help troubleshoot I would be willing to pay. I really need my vehicle up and running.
Re: Honda Accord 2.0t 10th Gen issues after Flashpro
So it is doing this on the stock calibration?
Have you checked for error codes?
echrispot@gmail.com
Hi! Yes I went through the return ECU to stock process. I went through the OBDII diagnostics as well and it was showing every error code. Since the engine wont start now I cant really do anything because the ECU cant connect to the flashpro correct?
Since it is returned to stock you should have this looked at by a Honda dealer to see what has happened in your vehicle. If they have to replace the ECU make sure you unlock the FlashPro before doing this.
rainy187
Post by rainy187 »
have you checked the fuel pump recall?
