Look for a basemap revision
MorpheusNeo
Hello, I am hoping to find someone who can make adjustments to my basemap with my data on my datalog. I want to be able to drive my car safely to my tuners dyno which is 20 min away and the basemap I have now isn’t going to work. I’m using the default hondata b16a2 tune with my parameters and things filled in but still idles not very good, it will hang in 13s then 11 then up to 20 and back, hoping to find someone who can help me out & send my tune back with modifications so I can drive it to the dyno.
Car is B16a2 semi built, e85, 400lph fuel pump, ID 1000cc, fpr, skunk 2 intake, 1320 race header, adjustable cam gears & head features ferrea 5000 valves full head package, cams I think are stock. Basically just need a kind soul to help me be able to drive this thing to the dyno so I can get a proper tune, don’t want to pay my tuner twice tor the same job.
I understand its going to take more than an idle datalog to fill out the driving map, but hopefully someone can get me in the right direction. If someone can get my car running and driving okay I can pay money if needed for your help
- CalibratEd
- Contact:
Re: Look for a basemap revision
I can take a look it at. What wideband are you running?
Do you have the deadtimes for your injectors?
- Ed
- Ed
Instagram: calibrated.tuning
MorpheusNeo
Okay thank you!! Attached I have an image of my injector deadtimes from my previous dyno tune calibration file :) Wideband is AEM Series X Wideband (part number: 017-30-0300) which I have also calibrated with the voltage offsets from previous tune
- CalibratEd
- Contact:
What all have your modified in the calibration file you posted.
-Ed
-Ed
MorpheusNeo
Sorry this is the most recent updated calibration file. I put in deadtimes, wideband voltages, rev limit, gear comp & lean protection. Essentially copied over all the vital information from my previous tune. Also there is 65% overall trim to the entire map and it won't run without it because fueling isn't touched, added a bit on the idle cells but thats it, I know 65% overall trim isn't good but i'm sure you will help with that :)
MorpheusNeo
Idles in 11-14.7 range with copied fuel
- CalibratEd
- Contact:
Can you post a datalog that pertains to this calibration file.
- Ed
MorpheusNeo
Yes no problem, I will send it after this weekend is over, thank you for your patience I have a brain injury and its hard for me to get things right. If its easier for you, add me on facebook its Carmen Martini picture is EG hatch
- CalibratEd
- Contact:
Carmen,
Unfortunately, I don’t have Facebook. No worries just post it when you can.
-Ed
-Ed
MorpheusNeo
Sorry it took a day longer to reply, here is the updated tune with 2 datalogs of just idle & other was slight revving
MorpheusNeo
By the way I forgot to add that the plug gap is 0.52 as of current & plugs are NGK BKR 6
MorpheusNeo
Third basemap up to temperature.
PS: will send coffee money if you can get the car running right
- CalibratEd
- Contact:
I cleaned up some of the fuel at idle. Try to make a normal driving log if you can.
-Ed
-Ed
MorpheusNeo
Idk what you did but car won’t even start. probably just gonna trailer it I don’t want to get the engine messed up trying to do E tunes man car won’t even start…. thanks for the effort anyways but whatever you sent me was wayyyy too lean
- CalibratEd
- Contact:
