B18c1
jmbergin
B18c1
Post by jmbergin »
Good evening please excuse the inexperience very new to this. I have a 91 hatch built for circle track racing. Car has a built B18c1 run on a p28 s300. I will attach build sheet, car was tuned on a dyno and ran great. We have since taken it to the track and it refuses to rev past 5k. Tried a stock p28 tune with the s300 no problems reving past 5k. We even plugged in a stock p28 ecu runs ok and revs past 5k with ease. I feel like it's a simple fix but we are just lost.
Thank you
CalibratEd
Re: B18c1
Post by CalibratEd »
Did you double check to make sure the hondata s300 module is seated properly in the ecu? If the car ran fine after the dyno tune and nothing has been changed than it might be a hardware.
-Ed
Instagram: calibrated.tuning
jmbergin
Re: B18c1
Post by jmbergin »
Ed, we did check that even bought a new socketed ecu hoping that was the issue. Still runs the same on both ecu's.
Very frustrating. Thanks for the suggestion!
CalibratEd
Re: B18c1
Post the calibration file you are having trouble with. It could be something as simple as launch control not working well due to a failing vehicle speed sensor.
-Ed
jmbergin
Re: B18c1
Post by jmbergin »
Ed,
Here is the program the tuner sent me
CalibratEd
Re: B18c1
Can you create a datalog as well with the issue present.
-Ed
jmbergin
Re: B18c1
Post by jmbergin »
I can most certainly try. It will be later this afternoon. So just have the car run and try to rev past the 5k?.
CalibratEd
Re: B18c1
jmbergin wrote: Fri Jun 30, 2023 10:22 am I can most certainly try. It will be later this afternoon. So just have the car run and try to rev past the 5k?.
Yes, normal drive the car so that it hits the limiter.
-Ed
jmbergin
Re: B18c1
Post by jmbergin »
Ed,
Hope this works i seem to have trouble datalogging
jmbergin
Re: B18c1
Post by jmbergin »
I was able to find this saved on the computer. I know we had issues that day at the track but I am not 100% sure this fully shows all the issues. I did send this to the turner and he only replied " only thing I see is your barley get above 30% throttle" Correct i cannot get to wide open throttle because the car cuts out around %K.
CalibratEd
Re: B18c1
Try this file. I turned off the Launch control just in case that is the issue.
- Ed
jmbergin
Re: B18c1
Post by jmbergin »
I will do that ans let you know.....thank you very much
CalibratEd
Re: B18c1
jmbergin wrote: Fri Jun 30, 2023 5:02 pm I will do that ans let you know.....thank you very much
No problem.
-Ed
jmbergin
Re: B18c1
Post by jmbergin »
Ed,
That worked I was able to rev up past 5k no issues. My next question is what and why was the launch control set and do I need it for circle track racing. Again thanks again
CalibratEd
Re: B18c1
I don’t know why the launch control was set for you. I normally ask my customers if they need it active. Launch control helps when going from a stop. It hold the rpm for you when you hold down pedal. I don’t know if you do much launching in circle racing. How do you normally get off the start line?
This issues tends to happen when your vehicle speed sensor starts to go out. Your tuner should have spent a bit more time reviewing your logs.
Reach out if you need anything else. I’m glad I could help.
-Ed
