Post-tune radar-related errors?
Civic 2016+ 1.5 Turbo
MicRouS
Post by MicRouS »
I've just started tuning and the +3psi base tune worked find. Wanted to see what +6psi is like, so I added that to my hondata and reflashed. Ever since then, my collision mitigation system, adaptive cruise control, lane departure mitigation, and auto-high beam refuse to enable and I get the respective "problem" errors on boot. Also got a check engine light. Tried reflashing to the +3psi and got the same errors minus the check engine. Tried reflashing to stock and got the same errors minus the check engine. Any advise on what could be the issue? I did also enable stage 1 throttle response on the +6psi tune in case that makes a difference.
MicRouS
Re: Post-tune acc and lkas errors
Post by MicRouS »
Just to be clear, I had none of these errors on the first attempt of the 3+psi tune.
Re: Post-tune radar-related errors?
When you datalog what errors are reported?
MicRouS
Post by MicRouS »
Apologies for the unnecessary thread. Seems I just needed to go for a longer drive. They all simultaneously disappeared.
