K20a2 00Ek tuned/calibration
JaviBori1
Post by JaviBori1 »
Sorry in advance if I post it in the wrong spot but I need help with my swap.
After rebuilding the top end of the engine and put it all back together and taking it for a ride down the street back-and-forth I keep getting a knock sensor code. I have not tuned the car yet I just want to make sure everything is 100% good before I take it to the tuner
And another lil problem is battery light starts dimming light to bright lil by lil 🤷🏽‍♂️
And yes this is my first Kswap ever 😑
96-00 Honda Civic Mandrel Exhaust by TruBendz - 3" Aluminized Steel Tubing
K Series K20 K24 Megaphone Pipe Header Exhaust 3" 4-1 Tri-Y EK EG DC2 Civic V Band Down Pipe
SKUNK2 TUNER STAGE 1 ONE CAMS CAMSHAFTS FOR ACURA RSX TSX HONDA CIVIC SI K20 K24
Skunk2 Pro Series Intake Manifold for Honda EP3/DC5 K20A K20A2 K20Z1 K24A1 Swap
Skunk2 Alpha Series Valve Springs and Ti Retainers K20 K20A2 K20Z1 K20A3 K24A4
ACUITY Throttle Position Sensor TPS HALL EFFECT FOR R$X-S EP3 CIVIC SI K20 1879
K-Tuned 4 BAR MAP Sensor for K-Series
Honda Engines
ATI Street Super Damper Crank Pulley 918477
for Acura Honda K20A K20A K20Z K24
SKUNK2 ALPHA FORGED VALVE DISH FACE/ STD COMP SET FOR HONDA/ACURA K20 K...
CAMSHAFTS FOR ACURA RSX TSX HONDA...
Skunk2 Racing 309-05-0090 Pro Series Hard Anodized 74mm Throttle Body for Acura Honda K-Series Engines ( port machine throttlebody to intake manifold )
I put the Hondata K Pro recording
Files
-10 min idling
-Cruising down the street
-And one with pull
Thank you in advance
JaviBori1
Re: K20a2 00Ek tuned/calibration
Post by JaviBori1 »
JaviBori1 wrote: Sat Jul 08, 2023 7:40 pm Sorry in advance if I post it in the wrong spot but I need help with my swap.
Honda Engines
1000cc Honda / Acura K20 K24 2.0 2.4 SouthBay Fuel Injectors
Files
-10 min idling
-And one with pull
CalibratEd
Post by CalibratEd »
I don't see a knock sensor code in the logs.
In regards to the battery light, double check connections to the alternator are ok. Check the belt as well. If all this is fine then your alternator might be going bad. I see that the voltage is dropping in the log.
-Ed
Instagram: calibrated.tuning
JaviBori1
Post by JaviBori1 »
The knock sensor code is on the ( cruising..kdl files ) about 40sec in
and ok I will get a alternator coming.
CalibratEd
JaviBori1 wrote: Mon Jul 10, 2023 1:22 pm The knock sensor code is on the ( cruising..kdl files ) about 40sec in
I will take a look at it again when I get a chance.
-Ed
JaviBori1
Post by JaviBori1 »
Ok TY
CalibratEd
I see the code now. Check if the connector to the knock sensor is loose. Check the wiring as well.
-Ed
JaviBori1
Post by JaviBori1 »
yes i put a new PLM kseries knock sensor
with a new pigtail
and we check continuity from plug to pcm
CalibratEd
Any reason you didn’t go oem?
-Ed
JaviBori1
Post by JaviBori1 »
The oem one did not work either
CalibratEd
You might and electrical issue or ecu issue.
-Ed
JaviBori1
Post by JaviBori1 »
Ok i will see what I could find out
JaviBori1
Post by JaviBori1 »
Is it normal for the knock sensor voltage to drop to 0 while driving?
