HKS CAI installed in FK8 idle upand down sticky Tplate
Grishnatch
Post by Grishnatch »
Hello!
Installed the cold air intake about a week ago and the tuner and I have been hard at work to try to fix the AFRs. Everything seems to work fine as soon as i step on the gas, until the car gets nice and warm. Idle starts to go up and down on it's own and i start to get a few codes.P0101, rev match system error and P0103. It's even screwing with my T.Plate% and causing rev hang! I do have datalogs to go with post if anyone is interested.
Does anyone have a map that i can go off of as the e tuner im working with doesn't seem to understand what i'm trying to say..
I can disable all errors that are popping up but it's just a band-aid and it doesn't get rid of the sticky throttle plate.
Thanks!
- Shawn
Re: HKS CAI installed in FK8 idle upand down sticky Tplate
Post the calibration and a datalog showing when the error occurs.
Grishnatch
19:30M the idle starts acting up at around 1500rpm down to 1K. 24M is another snippet of it and at around 34M. Calibration is attached as well.
At about the 1:35 mark you get an error code for P2261 (turbocharge bypass control valve stuck closed) that needs to be addressed before anything else.
