Purchased an S2000 and removed the SC. I can't get tune to stock.
9KRPM
Post by 9KRPM »
Hi, so I'm a bit stumped. Here is the scenario. 2003 S2000, had a Vortech SC kit on it, bigger injectors etc. It was tuned by Bisimoto.
It has a K Pro V4 BT. I can't for the life of me figure out how to return it to a stock tune after removing the parts. It will still have the Comptech header, intake and exhaust. Stock injectors are back in place.
I see the current tune. How do I revert to stock? Do I need to download a stock generic tune or will it be stored somewhere.
MondeCruel
Re: Purchased an S2000 and removed the SC. I can't get tune to stock.
Post by MondeCruel »
There is a calibration for s2000 if you do >file>new>vehicule type>S2000AP1
The only way to actually return to stock is to putt eh OEM ECU back in and change the sensors and valve cover back to the original ones.
9KRPM
Post by 9KRPM »
Spunkster wrote: Fri Jul 14, 2023 2:25 pm The only way to actually return to stock is to putt eh OEM ECU back in and change the sensors and valve cover back to the original ones.
Why couldn't I run the current ecu/kpro in stock form? I plan on having it tuned soon with the current bolt ons. Sensors are all stock again. How is the tune effected by the valve cover?
9KRPM
Post by 9KRPM »
MondeCruel wrote: Fri Jul 14, 2023 1:56 pm There is a calibration for s2000 if you do >file>new>vehicule type>S2000AP1
Thanks, I will take a look.
