s300 v3
staticsergio
s300 v3
Post by staticsergio »
Hello, I was driving in low rpms and shifted into second gear then my car died in the middle of the street and my hondata shows a flashing red light and won’t connect or do any data logging with my computer any answers to this?
Re: s300 v3
Did you miss shift?
staticsergio
Re: s300 v3
The serial number is 61541 and the software is 2.8.3.0 and no it was a smooth shift i was at low speed low rpms, thank you
Re: s300 v3
Have you tried the ECU in a known working vehicle? It sounds like there could be a wiring issue somewhere in the vehicle.
staticsergio
Re: s300 v3
no I didn’t try it on a working vehicle I just had a refurbished ecu chipped with s300 yesterday to see if it was my ecu and it still has the flashing light I’m assuming your correct on the wiring
