AEM Wideband data logging
FlashPro questions & answers specific to the 2007-2008 Acura TL
jtsurdisvp@gmail.com
Post by jtsurdisvp@gmail.com »
Hello, I’m trying to figure out how to get the data log to work from my AEM wideband. I have it connected to the ECT two wires I’m not sure if I did something wrong or not does anybody have any advice or direction on how to figure this out
Re: AEM Wideband data logging
There is one ECT2 input on the ECU...you mention wires.. How exactly do you have it connected?
Have you selected the correct input on the calibration?
I figured out what I did wrong I didn’t have a grounded to the right location. I had it on the ground of the ECT2 wire Instead of the ground for the ECU, it is working now I did have to adjust the voltage offset to -0.7 and it seems to be correct on the data log now
Lifeisgainz
Post by Lifeisgainz »
Which wideband do you have? I have the AEM X series and I’m troubleshooting some issues now. The shop that installed it landed the black ground near the fuses to the chassis(which isn’t right according to Hondatas instructions) and it looks like they spliced the brown into a wire landed on the C plug that goes into ecu. These are the 2 I’m concerned with. Red is going to a fuse under the dash and white is landed on ECT2 spot on A plug for ecu(which seems correct and is set correctly in Flashpro).
I have the X series you need to ground it off to the point that’s on the thermostat housing
I do have it wired to the fuse box under the dash
What are you trying to troubleshoot?
I can give you more information if you message me on my Instagram @ Majestic_ua7
