FK8 5,500 rpm Hesitation issue Tune
YamahaR6
Post by YamahaR6 »
2018 FK8 with PRL intake with race PRL MAF and PRL turbo inlet and greddy supreme cat back exhaust.
issues arehesitations at 5,000 prm to 5,500.
P0101 code with PRL race intake mod selected as well with enabling p0101 mod selection to stop code from appearing; it still had came up (Tune 3)
Tried PRL intake with rampage and p0101 code enabled, had no code pull up but still issues with hesitations like boost cut still at 5,000 rpm+ ( Tune 6 )
Could you adjust this or tell me what needs to be done so my friends car that we are tuning can run on 91 pump gas, PRL full intake kit with MAF and turbo inlet, Greddy catback exhaust Supreme everything else stock.
Re: FK8 5,500 rpm Hesitation issue Tune
Don't drive the car like this. It is running 50% + rich.
Probably the AFM selection or AFM. The HVI race intake is selected - what intake is being used? Also make sure the intake tubes are straight and there are no leaks.
