Building Boost On 2Step
KendallBuilt
Post by KendallBuilt »
Does the spec of the wastegate spring and what you have the boost controller set at have a factor in how much boost you can build on the 2 step? Or can I just increase the value of the 1st gear cell in the “boost control/boost by gear” setting? Car is set up for boost by gear, just trying to leave on more power out of the hole. Thank you.
Re: Building Boost On 2Step
It all depends on if the wastegate is closed when trying to do that.
DaX
Post by DaX »
Use the launch control settings to turn up your 2-step boost.
Boost by gear is only for once the car is moving.
