Switching between Open Loop and Closed Loop with AC Switch
Full Spool
Post by Full Spool »
As the title states is this possible? If so my searched skills have failed me therefore I'm resulting to the forums. I would like to be able to toggle between open loop and closed loop settings using the AC switch. At the track I prefer to be in open loop but driving to local events i'd prefer to switch it to closed loop with out having to get the laptop out.
D16z6
PO6 chipped with s300
SManager 2.8.3.0
AEM wideband- fed to ecu
Thanks for your help!
Re: Switching between Open Loop and Closed Loop with AC Switch
No, you cannot do this. You would need to upload a different calibration when you want to change this.
DaX
Post by DaX »
Won't you already have the laptop out at the track? If so, drive around town with it in closed loop (no laptop required), then when you go to the track and plug the laptop in, switch it to open loop. Then, just put it back in closed loop before you leave the track.
The closed loop tab does let you adjust max MAP and RPM for closed loop, so you could make it go into open loop based on one of those two parameters.
