MR2 kswap
DealerDom
MR2 kswap
Post by DealerDom »
Hey, im new to the hondata/car scene. Im currently running a 1991 mr2 with a 08 tsx k24, 02 rsx type s transmission, 02 rsx type s engine harness and a type s oil pump. I'm trying to see why the car doesn't have spark. What I seemed to find is the immobilizer is enable by default. What I see is you have to create a calibration to disable it. This is the part where im confused at; As of now im running the (tsx 04-05 stock.kal) calibration. I wanted to see if this calibration would be fine to run so I can see if I'm getting spark. If you need more information please leave a comment.
Thanks,
CalibratEd
Re: MR2 kswap
Post by CalibratEd »
Welcome to the forum,
Under the Misc tab check if the immobilizer enabled is unchecked. If so then the immobilizer is turned off.
-Ed
Instagram: calibrated.tuning
