2023 civic sedan ex 1.5t … flash pro date?
Raventracker25
Post by Raventracker25 »
As in the title. I am wondering when y’all will have the ecu available for the 2023 civic sedan ex 1.5t for the hondata flash pro. I was told months ago that it would be shortly and that you all have gotten the ecu from Honda them selves .
Just curious if it’s still a ways out or if there is an estimated timeline?
Thank you
Re: 2023 civic sedan ex 1.5t … flash pro date?
What is your ECU part number?
Raventracker25
Pic is attached
37805-64A-AC10
IT is supported with the release of software today: https://hondata.com/software?route=info ... nformation
Raventracker25
I notice they have the 2023 factory setting available now. What is there to gain using that one.. I was thinking that there would be the 91octane option like the 2022 has or options to chose which aftermarket bolt ons are installed
Raventracker25
so i went with the 2023 civic factory settings tune. I was looking for the one where for the 2022 models they were provided with a estimate 34hp increase I'm not sure if this is the same one or what option to choose. after going with this factory setting though now my cruise control and lane avoidance warning lights are on along with my brake system lights.. how do I go about fixing all this now?
for something to be a simple plug and play came with some difficulties
You can use any of the 2022 calibrations listed and they will work.
Go to the online menu in the software and then click on OBDII diagnostics and try clearing the errors from there. If any remain, you will just need to drive it until they go away on their own.
Raventracker25
That worked and all my warnings went away! Thank you
Will there ever be an update on choosing to select what Bolt ons we have done such as cold air . After market exhaust
Example (KN cold air, 27 won down/front pipe)
Or even to select the upgraded 4bar map sensor. I heard if you install those (map sensors) without being able to select you have em will mess things up
I don't know what updates will be available in the future.
