fc1 original turbine can use +9psi
Civic 2016+ 1.5 Turbo
zhangxin
Post by zhangxin »
I'm an fc1 mt. Replaced a straight header. Through research, it is found that the ignition logic and air-fuel ratio of +3psi +6psi +9psi are the same, only the turbine pressure is different. I want to know whether the original turbine can withstand the turbine pressure and heat of +9psi, and whether occasional violent driving will cause damage to the engine or turbine
Re: fc1 original turbine can use +9psi
We are not aware of any issues using this.
zhangxin
Post by zhangxin »
This +9psi calibration does not correspond to the original turbocharger? I am using +9psi calibration now, so it should not explode
It was tuned on the stock turbo.
