Hybrid intake base tune fine tune please
SICcivic
Post by SICcivic »
Hybrid intake works fantastic on 07 si. using base map from hondata seems good but I would like to fine tune the car.
Any body have some advice or suggestions. Ready to do some data logs.
CalibratEd
Re: Hybrid intake base tune fine tune please
Post by CalibratEd »
Post the calibration you are running and a datalog. Make sure the car is running in speed density. After an intake upgrade these cars run a lot better in speed density. Dial in the fuel and make sure the car is not knocking.
- Ed
Instagram: calibrated.tuning
SICcivic
Post by SICcivic »
Ok I will post soon. speed density is map correct? Vs. maf?
CalibratEd
SICcivic wrote: Thu Aug 31, 2023 2:12 pm Ok I will post soon. speed density is map correct? Vs. maf?
Yes, speed density means MAP.
-Ed
Austin09fg2
Post by Austin09fg2 »
OP were you able to find a tune to run the hr cai? I am in the same boat just finish install and now looking for a tune and im a little confused. There is no hr cai option in hondata soo... do i just keep stock and switch to map or switch to another cai and just make sure its map based instead of maf?
