k24a2 turbo tune
whittben137
k24a2 turbo tune
Post by whittben137 »
Hey guys I'm looking for a base tune for my EG. I just started it up with the swap all done. Its idling and running fine, its on a base tune from the NA tune. Looking for a base tune for my build so i can drive it around the garage safely until it hits the dyno. thanks for any input. My build is as follows:
K24A2 block and head
ID1000 injectors
AEM 340 E85 fuel pump
Aeromotive fuel pressure regulator
Kpro4
50 Degree vtc
type s oil pump
RBC intake
AEM wideband
4 bar map sensor
Pulsar T3 GTX gen2 ball bearing turbo 60mm i believe
ATK sidewinder manifold
44mm waste gate with 10 psi spring (for now, have sensor just not installed )
type s flange blow off valve
3" APEXI exhaust
CalibratEd
Re: k24a2 turbo tune
Post by CalibratEd »
Have you reached out to your tuner to see if they can provide you a base map?
-Ed
Instagram: calibrated.tuning
