Hello.
I recently purchased and installed a Mishimoto SRI as my only engine modification. I have tried using hondata's K&N SRI basemap as it seems the intakes are relatively similar. Unfortunately, I encounter a ton of knocking at high load and feel uncomfortable using it. I'm currently using a hybrid map from another post calibrated for a K&N intake which works relatively well with my setup and shows minimal knocking. However, I would like some help fine-tuning a map for my specific setup if possible. Any help would be appreciated, thanks.
Requesting help with an SRI basemap
Re: Requesting help with an SRI basemap
Here is the map I'm using currently and a datalog of a drive home.
- CalibratEd
- Contact:
Have you removed timing in areas where you see knock? I would start with that and make sure the fuel is ok as well.
-Ed
-Ed
Instagram: calibrated.tuning
