need help with a tune
ibarra1557
i have a 98 integra lsvtec build, Has a B18c5 head on a B18b1 bottom end
Mod List:
-Cold air intake
-Forged weisco pistons
-Forged eagle rods
-10:5:1 comp
-Bore 81.5 i believe
-Brian Crower valvetrain
-Brian Crower stage 2 Boost cams
-Toda Cam gears
-Supertech titanium valve springs and retainers
-Head was ported and polished
-Acl rod and main bearings kit
-Arp Studs
-Cometic Head Gasket
-Gsr water pump and belt
-Act six puck clutch extreme
-Gsr trans hydro
Has stock injectors Let me know if you can help thanks!
Mod List:
-Cold air intake
-Forged eagle rods
-10:5:1 comp
-Toda Cam gears
-Arp Studs
-Gsr trans hydro
ibarra1557
Re: need help with a tune
ibarra1557 wrote: Sat Sep 09, 2023 9:36 pm i have a 98 integra lsvtec build, Has a B18c5 head on a B18b1 bottom end
Mod List:
-Cold air intake
-Forged eagle rods
-10:5:1 comp
-Toda Cam gears
-Arp Studs
-Gsr trans hydro
Hey i can recommend a tuner guy, look him up on fb his name is mohammaed nabil , nabil tuned hes done mine and its been well
ibarra1557
update, Added tri y headers to full straight pipe exhaust 3"
ibarra1557
Files for you
- CalibratEd
- Contact:
ibarra1557
Not yet putting in today or tomorrow been super busy with work
- CalibratEd
- Contact:
ibarra1557
hers a update
- CalibratEd
- Contact:
The car is running a bit rich in Vtec. That's all I can gather as its a very short datalog.
- Ed
Instagram: calibrated.tuning
ibarra1557
this is a tune log with wideband installed when cruising it runs at 15 sometimes 14s on afr
ibarra1557
also have these hope they help ill do one tomorrow at cold start/ driving to work and all, Get some fresh ones
ibarra1557
Fresh Data log from today these are more accurate
ibarra1557
and 1 more
