K20A PRA ECU Base map required, will pay.
JCL
Post by JCL »
Afternoon (or whatever time you're reading this).
Got a slightly urgent situation, we have a EP3 that had a K20A2 engine, its had a recent rebuild and DC5 pistons & Cams installed during the process, (I believe making it a K20A), however there are no base maps on Kpro for A K20A with a PRA ECU, our usual tuner is booked up until November and we've got a hill climb and two track days either side of that, I'm hoping that someone will have a map that will suit, as per the header happy to tip someone for the right map.
K20A Engine (I/H/E)
Intake manifold
Full custom straight through exhaust
Cold air intake
Or should I just stick with the K20a2 base map (factory), or K20a2 ITRcams hdr map on Kpro and await a tune in November?
Thank you all in advance.
CalibratEd
Re: K20A PRA ECU Base map required, will pay.
Post by CalibratEd »
Any calibration you use will need adjustments. You can run the k20
Calibration on the PRA ecu. To my knowledge the PRA does not have an OEM wideband so you will have to run an aftermarket wideband. I can help dial it in to make sure it’s running safe.
-Ed
Instagram: calibrated.tuning
