Need help on k24a2 on 8th gen civic si
Ajrsx
Post by Ajrsx »
Need a correct base map for a 8th gen civic si with k24a2
Rbc manifold
Type s oil pump
Rdx injector
Ktuned throttle body
CalibratEd
Re: Need help on k24a2 on 8th gen civic si
Post by CalibratEd »
I suggest you start with the stock calibration set it to speed density and dial it from there. I can review the logs and make sure the car is running safe until you get it properly tuned.
-Ed
Instagram: calibrated.tuning
Ajrsx
Post by Ajrsx »
Can you help me with the tuning?i can do some datalogging
CalibratEd
Ajrsx wrote: Thu Sep 14, 2023 3:23 pm Can you help me with the tuning?i can do some datalogging
Yes I can help review logs and make adjustments to make sure the car is running safe.
-Ed
Ajrsx
Post by Ajrsx »
Thank you ill do some datalogging this weekend ..how should i drive it?
CalibratEd
Ajrsx wrote: Thu Sep 14, 2023 8:16 pm Thank you ill do some datalogging this weekend ..how should i drive it?
Normal drive the car.
-Ed
