HONDATA FOR 37820-5HW-K51 ECU?
Dabb
Post by Dabb »
Hi,
I am looking for a flash pro unit for a HRV with a R18Z engine using a 5HW-K51 ecu. Using the app at the website, the ECU isnt listed as supported.
Can this ECU be used? If not, which ECU do you recommend me to buy in order to use Hondata in this engine with a low pressure turbo and a PWM turbo wastegate.
Kind Regards,
DB
Re: HONDATA FOR 37820-5HW-K51 ECU?
I'm sorry but this vehicle with this engine is not supported. We do not offer anything for it.
Dabb
Post by Dabb »
Thanks Spunkster for your reply.
Which ECU serial numbers do you advice me to find in order to use with Hondata to manage this engine?
Kind Regards,
DB
We do not recommend or support trying to swap ECUs.
