Kpro v4 connection problem on-line off-line
kpro v4 I have a problem connecting and disconnecting (on-line/off-line) I changed the cable thinking that was it, it gives me an error
Re: Kpro v4 connection problem on-line off-line
It connects on-line and after a short time it disconnects off-line by itself and like this every moment, I don't have time to do anything, I changed the cable thinking that was it
MondeCruel
Make sur you have internet connection at the time you launch kmanager
being connected to the internet the same thing happens, it connects and disconnects all the time
Are you using resistor or non-resistor type sparkplugs.
Using resistor
When did this problem start, and what has been changed since the last time it was working?
I think my notebook was not working well, I reinstalled everything again and so far it works correctly.
good to hear
