Kpro a/f fixed
EGK2082
Kpro a/f fixed
Post by EGK2082 »
I have a problem with kprov4, my indicator in kmanager a/f is fixed at 17.69, but my o2 voltage indicator works, my short trim also works, it is recording data and has a signal, I don't know why the a/f is fixed
airfuel.kdl
k20airfuel.kal
CalibratEd
Re: Kpro a/f fixed
Post by CalibratEd »
Are you using the stock wideband sensor or an aftermarket sensor? Make sure to select the proper wideband input in kpro settings. If the proper one is not selected it will not populate the data.
If I select to display the oem wideband I can see data populate. If I select the Aem wideband (Analog input 0) no data is populated.
- Ed
Instagram: calibrated.tuning
EGK2082
Re: Kpro a/f fixed
Post by EGK2082 »
OEM o2 sensor, it always worked fine, suddenly it was fixed.
EGK2082
Re: Kpro a/f fixed
Post by EGK2082 »
Suddenly I became static in 17,69
CalibratEd
Re: Kpro a/f fixed
I was able to see the data. Is the datalog you posted recent? In the log I didn’t see areas that were lean but it was not static at 17.
-Ed
EGK2082
Re: Kpro a/f fixed
Post by EGK2082 »
Yes, recent, I see it as static.
CalibratEd
Re: Kpro a/f fixed
EGK2082 wrote: Tue Sep 19, 2023 10:27 am Yes, recent, I see it as static.20230919_142542.jpg
Did you change the setting I mentioned?
What do you have set in the kpro wideband input settings? This is part of the software and not the calibration file.
-Ed
EGK2082
Re: Kpro a/f fixed
Post by EGK2082 »
yes thanks, problem solved
CalibratEd
Re: Kpro a/f fixed
EGK2082 wrote: Tue Sep 19, 2023 12:37 pm yes thanks, problem solved
Im glad I could help. Good luck on your tuning endeavor. Reach out if you have any questions.
-Ed
EGK2082
Re: Kpro a/f fixed
Post by EGK2082 »
thank you so much
