K24 swapped 8th gen SI basemap
MrJumpStars
Hi fellas! The k20z3 on my 08 civic si cracked so a shop swapped it with a jdm k24a. I bought hondata flashpro to get the engine to run normal but I'm realizing it doesn't come with a basemap for the k24 swap. Can some help me? I don't have any mods on my car - stock intake box, rbc manifold, exhaust, etc. It's all stock except for the engine. Do I need to download a basemap from this website? I'm a noob to all of this. Any help would be beyond appreciated. Thank you!
- CalibratEd
- Contact:
Re: K24 swapped 8th gen SI basemap
Welcome to the forum,MrJumpStars wrote: Fri Sep 22, 2023 1:50 pm Hi fellas! The k20z3 on my 08 civic si cracked so a shop swapped it with a jdm k24a. I bought hondata flashpro to get the engine to run normal but I'm realizing it doesn't come with a basemap for the k24 swap. Can some help me? I don't have any mods on my car - stock intake box, rbc manifold, exhaust, etc. It's all stock except for the engine. Do I need to download a basemap from this website? I'm a noob to all of this. Any help would be beyond appreciated. Thank you!
You select the calibration file you want to run from the software. You can choose the stock calibration, switch it to speed density and make adjustments to get it running safe until you get it properly tuned.
If you search the forums I think EFICU was working on a k24 swapped 8th. You could also use that as a start.
-Ed
Instagram: calibrated.tuning
MrJumpStars
Oh my god thank you! I'll try that nowCalibratEd wrote: Fri Sep 22, 2023 1:58 pmWelcome to the forum,MrJumpStars wrote: Fri Sep 22, 2023 1:50 pm Hi fellas! The k20z3 on my 08 civic si cracked so a shop swapped it with a jdm k24a. I bought hondata flashpro to get the engine to run normal but I'm realizing it doesn't come with a basemap for the k24 swap. Can some help me? I don't have any mods on my car - stock intake box, rbc manifold, exhaust, etc. It's all stock except for the engine. Do I need to download a basemap from this website? I'm a noob to all of this. Any help would be beyond appreciated. Thank you!
-Ed
- CalibratEd
- Contact:
No problem. Just keep in mind any calibration file you use will need some adjustments as no two cars are alike.MrJumpStars wrote: Fri Sep 22, 2023 2:09 pmOh my god thank you! I'll try that nowCalibratEd wrote: Fri Sep 22, 2023 1:58 pmWelcome to the forum,MrJumpStars wrote: Fri Sep 22, 2023 1:50 pm Hi fellas! The k20z3 on my 08 civic si cracked so a shop swapped it with a jdm k24a. I bought hondata flashpro to get the engine to run normal but I'm realizing it doesn't come with a basemap for the k24 swap. Can some help me? I don't have any mods on my car - stock intake box, rbc manifold, exhaust, etc. It's all stock except for the engine. Do I need to download a basemap from this website? I'm a noob to all of this. Any help would be beyond appreciated. Thank you!
-Ed
-Ed
MrJumpStars
I wish I knew exactly what to calibrate though. I’ll just wait and take it to the tuner. When I drove the car after uploading the tune, it shut off mid-drive, then the engine and both vsa lights came on :(CalibratEd wrote: Fri Sep 22, 2023 3:11 pmNo problem. Just keep in mind any calibration file you use will need some adjustments as no two cars are alike.MrJumpStars wrote: Fri Sep 22, 2023 2:09 pmOh my god thank you! I'll try that nowCalibratEd wrote: Fri Sep 22, 2023 1:58 pm
-Ed
-Ed
- CalibratEd
- Contact:
I can help make it run safe until you get it properly tuned.
Post the calibration file and datalog.
-Ed
-Ed
MrJumpStars
Okay I’ll drive it around later and send everything. I appreciate the helpCalibratEd wrote: Fri Sep 22, 2023 5:38 pm I can help make it run safe until you get it properly tuned.
-Ed
- CalibratEd
- Contact:
MrJumpStars
This is the EFICU basemap I used: This is the datalog from 10 minutes ago:
- CalibratEd
- Contact:
Car was running lean. I adjusted fuel.MrJumpStars wrote: Sat Sep 23, 2023 10:41 amThis is the EFICU basemap I used: Sebastian.SD.Rev02 (0Cam)(Vtec5500).fpcal
This is the datalog from 10 minutes ago: K24..SI.Sept23.fpdl
Create another log.
- Ed
MrJumpStars
While I waited I tried this tune: This was the datalog from it: I just uploaded your tune and I'll reply with it's datalog.CalibratEd wrote: Sat Sep 23, 2023 12:59 pmCar was running lean. I adjusted fuel.MrJumpStars wrote: Sat Sep 23, 2023 10:41 amThis is the EFICU basemap I used: Sebastian.SD.Rev02 (0Cam)(Vtec5500).fpcal
Create another log.
- MrJumpStars_Rev1.fpcalEd
MrJumpStars
Here is the new tune:MrJumpStars wrote: Sat Sep 23, 2023 1:24 pmWhile I waited I tried this tune: Sebastian.SD.Rev14 (Blended)(Vtec4200).fpcalCalibratEd wrote: Sat Sep 23, 2023 12:59 pmCar was running lean. I adjusted fuel.MrJumpStars wrote: Sat Sep 23, 2023 10:41 am
Create another log.
This was the datalog from it: MJS.Datalog002.EFICU.fpdl
- CalibratEd
- Contact:
Fuel is good and no knock is present. This should be good to normal drive (no WOT) until you get it properly tuned.
Reach out when you're ready for a full Etune if you don't already have a tuner. My info should be in the calibration file.
- Ed
- Ed
MrJumpStars
Thanks Ed! I couldn't have done this without you! You're the man!!CalibratEd wrote: Sat Sep 23, 2023 5:53 pm Fuel is good and no knock is present. This should be good to normal drive (no WOT) until you get it properly tuned.
- Ed
- CalibratEd
- Contact:
