Hondata App and Fuel Pressure
Ziradon
Post by Ziradon »
Hi,
i use the Hondata APP for IOS, Version 1.5.3.
Car is a FK8 equipped with Flashpro and the Hondata Fuel System Upgrade.
On the Hondata APP my fuel pressure shows always 0.
The flashpro datalogs and other OBD Tools (Autel) shows the correct fuel pressure.
I wonder if this is a bug, because i am sure to see a fuel pressure reading on older app versions?!
2020 Honda Civic Type R - European Edition
Re: Hondata App and Fuel Pressure
What sensor/channel are you using for fuel pressure?
Ziradon
Post by Ziradon »
There is only one sensor which is named Fuel Pressure. On the selection-menu it showed also active (white coloured) but unfortunatly did not show any numbers:
I'll pass this on to our app developer.
