Newbie, please tell me about using Hondata with FL5
xsx55kai
Post by xsx55kai »
Newbie, I have some questions about hondata. My fl5 is a Japanese version and the car is in Thailand. There are very few gas stations in Thailand that have pure 95 gasoline. So I chose shell 95 v-power (E10). My car has been jailbroken using Hondata.
1. When Hondata writes the Japanese OEM base map, can it automatically match if it selects Pump gas (10% ethanol)? Do I still need to manually adjust the ignition?
2. For the Hondata base map, I chose the No. 91 oil version. Should I also choose Pump gas (10% ethanol)? Based on the same No. 91 oil base map, will there be any difference in the power data of pure gasoline and E10?
Re: Newbie, please tell me about using Hondata with FL5
You should not have to make changes unless you are getting knock.
Yes, you should choose that option and There may be a very slight difference in power, but it will not be much.
xsx55kai
Post by xsx55kai »
Thank you very much for your reply, I understand. I went out to test drive tonight and used flashpro to record. This is my log picture. Could you please help me check if everything is normal? I studied hard and checked, but I still didn't understand. I wonder if there was a knock?
datalog0000.fpdl
xsx55kai
Post by xsx55kai »
Spunkster wrote: Wed Oct 11, 2023 9:05 am You should not have to make changes unless you are getting knock.
datalog0000.fpdl
