hondata won't start on an 01 integra
shaisy
Post by shaisy »
I install the s200 today and my car doesn't start
I mean it crank but it does not start the car
somehow my injectors aren't turning on cause my fuel guage doesn't go up
I had a skunk 2 obd2 to obd1 harness with the s200 install on it
I'm not sure what is wrong, cause I had a p28 computer before and it worked fine running boost with a vafc
It's not the harness cause I plugged in my old p28 ecu and it worked fine
I do notice that the blue box of the hondata had a steady red led when the ignition is on . What does that mean?
What is wrong here
Do I need to run a wire to turn on my injectors?
Please help
thanks
Is the check engine light on?
Are you getting fuel and spark?
shaisy
Post by shaisy »
check engine is on
it won't turn on my fuel pump
i'm not gettin any fuel to ignite
Are you using an OBD1 ecu with a built in adapter harness? If so, look inside on the red circuit board and see if it says OBD2a or OBD2b.
shaisy
Post by shaisy »
i'm using a skunk2 jumper harness from obd2 to obd1 harnes
Exactly what ecu are you using and do you know if that ecu was functional before you used it with the Hondata?
shaisy
Post by shaisy »
i am using a p28 sent out from hondata
shouldn't it be plug and play when I get the hondata
or do I have to modify somthing
is there somthing I need to do or preloadthe software
what are you running
do you have hondata?
if so did you have the same problem or somthing similar
thanks again
What sized injectors are you running? Who burned your basemap? Who is your tuner?
It sounds as if you have a blank chip and the car is in limp mode becaseu of the fact that there may be no rim image on the chip you are using.
Bryson
Post by Bryson »
<--- having the same issues.
Its definetly in limp mode. I'm kinda thinking its due to the fact that I'm using a Moates burner.
91 CRX
2.0L B18C1 with T4/SC61
LoveFab
Precision
Honda-Tech.com
Summit
