Kpro harness plug burning
pumadunk
Post by pumadunk »
Hi,
My harness plug to the ecu started showing smoke after I put into ignition for a few minutes. Not sure what it was smoking as the harness looks to be good. I did notice the plug to the analog inside the Kpro was a little loose. I only use the analog for PLX wideband. Is the loose analog plug causing the smoke ?
Re: Kpro harness plug burning
Nothing should smoke. You need to determine what exactly is smoking and trace back and see what is shorted and fix it, as you may damage the ECU, the K-Pro or both.
