Map 4 bar sensor
Raventracker25
Map 4 bar sensor
Post by Raventracker25 »
When it comes to the 2022 91 octane base map y’all have for the civic cvt.
I was wondering when there will be an option to be able to ad map 4 bar sensors. Now that 27won has dropped there newest turbo for the cvt models the 4 bar map sensors will be needed..
Thank you
Re: Map 4 bar sensor
The MAP signal is shared between the engine computer and transmission computer. The transmission does not work correctly if the sensor(s) are changed.
