2019 SI Issue with WOT
Civic 2016+ 1.5 Turbo
Roci
Post by Roci »
I have 2019 SI running the 271 W1 tune with the following mods: 271 W1 Turbo and TIP, K&N Short Ram, PRL Intercooler, AWE Touring Exhaust. Traction control is enabled. The battery was replaced a couple weeks ago - don't think that his important, but wanted to mention. The engine runs fine except under WOT where around 5k the engine cuts out for lack of better description. It feels like I am hitting the rev limiter. I have attached data log where it occurs. I am running the latest beta version of the software. thanks in advance for any ideas on what might be happening.
Re: 2019 SI Issue with WOT
Post the calibration the datalog was made with.
Roci
Post by Roci »
Here it the calibration. thanks
It is full throttle shift as you are above 65% throttle. You need to set a higher threshold for it to activate.
Roci
Post by Roci »
Thank you! I need to keep better notes on what i change... really appreciate your quick attention!
