The car will turn on but the ecu seems to lose power and the car shuts off.
Posted: Wed Oct 25, 2023 1:19 pm
by Taboolul
I recently changed my ecu(P28) and aquired a hondata. Since putting the hondata in the car, it'll start but soon after die. When the car dies the hondata lights will turn off and a cel will turn on. Few seconds after it dying and the hondata turning off and the ecu im guessing, the hondata and the cel willl go away the fuel pump will prime and the car can start again. All brand new capacitors in the ecu and it worked before installing the hondata.
Re: The car will turn on but the ecu seems to lose power and the car shuts off.
Posted: Wed Oct 25, 2023 1:43 pm
Posted: Wed Oct 25, 2023 2:06 pm
by Taboolul
Version 2.8.3.0 build 3288
Posted: Wed Oct 25, 2023 3:37 pm
It looks like the capacitors have leaked previously and may have damaged the board and that could be the issue.
Posted: Sun Mar 03, 2024 3:30 pm
by Taboolul
Alright so after changing the caps i ran the car. The car died after about 10 minutes while a was cleaning up some extension cable because i had to boost the car. I assumed the board was damaged due to a leaking capacitor since that was a reply i had gotten here and a friend had a similar problem. I store the car for winter and just got it out recently. I ran the car since i wanted to see how long it would run for. It ran for over 30 minutes no problem never died. Ran it again later that day and the next just to see and same thing no problem and ran for over 30 minutes. So here i am wondering why its kot dying anymore and reasons as tk why my car could of died when i first installed the new caps
Posted: Mon Mar 04, 2024 11:19 am
We have no way of knowing what may have happened.
Posted: Mon Mar 04, 2024 1:31 pm
by Taboolul
I want to clarify something, its that i only let the car run until it died once after changing the caps and parking it for winter and ever since it came out of storage it has run fine. So do you believe that the board is damaged from a cap leaking?
Posted: Mon Mar 04, 2024 2:35 pm
It sounds like it is working now.
