What do I need to get VSS output working?
itgoes
Post by itgoes »
I have a PND manual ECU with Kpro v4 I am running in a swapped car with a cluster that takes 4000 PPM input. I am a bit confused about how to get a VSS signal output from the ECU. Some posts say it is not possible with an auto ECU which implies it is possible with manual? I read another post that says the auto ECU is the only one with VSS out.
Is there a particular speed input I need to use?
Re: What do I need to get VSS output working?
itgoes
Post by itgoes »
59817
What is the part number that is on the white plug inside of the ECU? Our notes indicate it was installed into an automatic ECU.
itgoes
Post by itgoes »
PND-A06
It seems that this is not the ECU that the K-Pro was originally installed into. Where did you get this K-Pro/ECU?
itgoes
Post by itgoes »
I swapped it from a PND-A55 to PND-A06
There is no VSS output on the ECU. The VSS signal comes from the sensor and goes to the dash and ECU. IF you input the vss signal directly to the K-Pro, only the ECU will be able to see and use the converted signal. It will not output from the ECU.
